Mac questions
5 Jun 2007
I'm hoping that someone can give me some help with a few questions I have. I'm thinking of getting a mac, but I will still need to use windows a lot. I heard there was something you can use to allow you to run both, but I don't know what the drawbacks are. Is it like running it within mac os or more like dual booting?
you can run both at the same time by running Windows virtualized, won't run at native speeds though
or dual booting which will run natively with little problem
VM drawbacks are you need a lot of RAM, and anything that requires any hardware acceleration doesn't run that well.
Also worth noting that a VM install "legally" requires a separate license. i.e you can't run Windows in a VM AND BootCamp on the same license key.
Unless you use parallels with a bootcamp partition? I thought...?
Also, how much RAM is needed to run something like Office 2007 on OSX.
I think you'd get by fine with 2GB, but for the price right now, 4GB makes sense.
What makes even more sense is office 2008 for mac...
All new Macs (ie. Those with Mac OS 10.5 "Leopard" installed) come with an application called Boot Camp.
Boot Camp allows you to repartition your hard drive and start the installation of another OS (Such as Windows). It will also burn a driver disc for you to get all your hardware like webcams, graphics cards, etc up and running.
Boot Camp is "real" dual booting. When you power on the computer, it will give you a choice of OS's to start. So you get the full hardware performance in your chosen OS. There is no emulation.
There are third party virtualization technologies out there (VM Ware, Parallels, etc) which allow you to install other OS's and run them from within Mac OS, so you have two OS's running at once. This has the benefit of not needing to reboot when you need to use another OS.
Personally, I prefer Boot Camp as I actually "feel" like I'm within Windows or Mac OS.
How come?
Because virtualising an application is always goign to be a bit slower. You can't just pop up excel quickly to look at a document, you have to wait for the VM to boot. Copy and paste can be a bit of an issue between the VM and native OS (not always and I haven't used parallels yet but I have problams with VM ware)
