mac shortcuts
12 Jun 2003
Wicklow, Ireland
just wondering is there shortcuts to do the following...
jump straight to desktop ala windows key + d in windows
and
in firefox if i type gmail into the address bar and then press ctrl + return it will fill in the http:// and the .com part of the address?
jump straight to desktop ala windows key + d in windows?
That's a feature of Expose, default is F11 or FN + F11, depending on what machine you're using.
awesome thank you,
just for future replies i'm using a brand spanking new macbook.
and
Yes, to do the auto complete press apple+return after you've typed gmail :)
