Macafee Anti Virus Problems
Caporegime
18 Oct 2002
London
McAfee Anti Virus Problems
Hi,
My friend is having problems with his computer and McAfee anti-virus. It seems to have quaratined 500 exe files from various folders including his windows 32 folder. Windows is having difficulty running without them and McAfee will only allow him to view the files in the quaratine folder. It seems to have added its own file extension too.
Using - Windows XP Pro & McAfee Anti Virus Enterpise 7.10
Any ideas?
sounds very weird, have u tried can you move them out the area at all?
could you try online scanner on the files its qauertined see if they are even effected?, if i was you id unistall
Mcaffe its not that good anyway and tell him to use Avast Free or Kaspersky.
Using - Windows XP Pro & Macafee Anti Virus Enterpise 7.10
Any ideas?
Is he using ePO if he's using the Enterprise version? By the way, that version is seriously out of date. Versions 8.0, 8.5 and 8.7 have been released since.
ps - it's McAfee, not Macafee ;)
Don't think it will allow him to move or edit the files
Will ask him to try that
Thanks ;):) - AFAIK, think it is his mum's PC
