Macbook Air 11inch
9 May 2004
London
Im looking at buying one of these to use as a secondary portable computer. Never owned a mac although Iv had a few iphones and ipods and always wanted to give mac OS a try.
Main uses will be general internet browsing, watching movies and tv shows and the odd simple game to pass the time.
Does anyone own one of these? What are your impressions? Hows the battery life?
I will likely go for the 4gb ram upgrade and maybe the 1.6ghz cpu although im not sure the cpu upgrade will really be required for what I will use it for.
I have mine for portable computing that requires a full OS .. amazing machine. Mine is the entry level with 2Gb RAM and 64Gb SSD. It's performance is WAY better than the specs would suggest .. for your uses it'd be more than enough so save the extra £££ IMO.
