Hi there fellow overclockers,
I have had my macbook air 13" since Sept 2012 and its been a fantastic little laptop. Last night I noticed what looked like screen burn in/ghost imprint on the screen. It was an inch long line on the left of the screen where the windows sit above the dock. I left my laptop on for the past two days straight but I thought LCD screens didn't get burn in that you would find on plasmas or CRTs. As far as I know Airs use TN panels and not IPS panels that the PROs use.
I have given the laptop a rest over night and fortunately the ghosting mark is now gone, is this normal or something that I need to start worrying about?
Edit: I thought the ghosting line was gone but it has started to come back after a couple hours use, not as bad as yesterday but a faint line is still visible on screen when you have a darker background.
Cheers
L
Cheers
L
i can only notice it on a grey background so when using mission control you can see it quite clearly. I'll give apple support a call, I have apple care so maybe they can sort me out.....hopefully
