macbook and wep woes.
6 Oct 2003
Trying to config so I have wep enabled on my netgear router and my macbook but I cant get it to work. i can use it fine when it is disabled. Any one have any tips?
BillytheImpaler said:
Why can't you get it to work? What are the symptoms of the problem? Are there any errors given?
If i knew why I could do something about it.(not having a pop) The symptoms are wireless is not working. No error messages. Configured pass word on router 128bit 13 character and the same on the macbook. preffered network is set to my network. nothing I have tried works.
Tap the AirPort icon in the taskbar and click the name of the wireless network you would like to connect to – if you are within range it should be listed there. In the pop-up change the Wireless Security drop-down menu from the default option, 'WEP Password' to 'WEP 40/128-bit HEX' Tap in your WEP key and hit OK.
It should remember the key in the future, and you shouldn't need to enter it again. Have fun with your mac! :)
*av
*av
For some reason it wont let me tap in the password nothing happens even though the cursor is in the password box :confused:
Still no joy i have tried lots of things for some reason it keeps on reverting back to wep key instead of hex. still cant enter text in the box also
