Man of Honour
- 15 Nov 2006
- Hull
Anyone else had this problem? Macbook says 'battery is not charging' in the menu bar. Solid green light on the charging connector. Have tried removing the battery and resetting the SMC.
Can't make the connector show anything other than solid green. Interestingly if I disconnect the charger the green light stays on. It even stays on for a while if I unplug it from the wall!
Does this point to a faulty charger, rather than a faulty battery / laptop?
Cheers guys.
Cheers guys.
