Macbook cd drive loud?
26 Aug 2005
London
Hi there,
I have a basic macbook and when I formatted it, I noticed a weird nosies from the CD drive when using the restore disks. Does anyone else have this?
It should spin up and make a lot of noise when there's lots of reading. But a crushy noise sounds bad. It usually sounds like a high rev spinning object, nothing crushy. Do you think there's something damaged?
Is it only for that disk or all disk?
Its a bit noisy when is reading at max but it doesnt sound like something is broken inside...
if you hear some sort of cracking it might be a fault :(
Will_3rd said:
i'm sure those noises are pretty standard, I wouldn't worry too much about them :)
Don't worry.. I;ve heard this before and it's nothing :)
