Hi there - need some help with a little problem
I got my 13" macbook in Sept 07 and shortly after bought a Netgear DG834N wireless router. I set the router up as instructed and initially everything seemed fine. Strong signal and very reliable connection to my desktop and also to the macbook, connecting through airport. However, I have found more recently than whenever I am in other parts of my house and using the mac to browse the net that after a few moments the page will fail to load and I need to go into Preferences and then Network and reconfigure the connection to the wireless network. I had not had this problem previously anywhere in the house. I have the router password protected and using the highest level of security and the mac has no trouble seeing the network. But is there maybe something I can configure on the mac (or router)to keep the connection constant or is it just one of those things with using wireless technology? The max range of the router is 270mps although I could lower this if it would make any difference.
Thanks for any advice you may be able to give me.
