macbook front edge?
28 Jul 2004
Hi,
I bobbed into the apple store at the weekend to have a look at the macbooks, as i am planning on getting a black one in the next few weeks.
However, when i was using it i realised how hard and sharp on the front edge seemed. Do you guys notice this when you're using it? whats the deal? I couldn't really tell whether it would annoy me as i was stood up at the time and the laptops are bolted in position to the tables (so not how i'd be using it).
Has even made me wonder now whether i should just stump up the extra cash and get the new mbp thats rumoured for release soon (ive been pondering between the 2 for ages now).
Cheers.
now you mention it,it is a bit sharp.
never really thought about it before..........Mmmmm where did i put that router LOL
Luckily i don't use it too much,i have an imac too.
Yes, it is quite sharp, and if you are using it for a long time you do get impressions in your forearm (well, I do).
It really doesnt hurt and only happens to me when I'm slouched on the sofa (I've had mine 14 months and used it almost daily so I've lived with it)
