Alright guys, I need some fresh ideas for a problem I've got.
A friend of mine has a MacBook. She bought it in January new so she's running 10.5.2 and I assume the draft n wireless hardware is in there. The ISP is tiscali but more importantly the wireless router shes using is a Linksys WAG354G.
When she first got it home it connected fine. A couple of weeks ago however the MacBook lost the wifi signal and since then has not been able to connect to the router. I haven't been able to work out whether shes been messing with anything but that's by the by now because I've reinstalled OSX and also reset the router to factory settings. It's still not working.
I've connected to the router using an ethernet cable and that works fine. When I try to connect via Airport the linksys doesn't always show up in the connection list, and when it does you click "connect", wait a few moments, and it throws a message back saying "connection timed out".
I've tried WPA2, WEP and turning the encryption off altogether - still no luck. I've even tried a long WEP key and the $ sign in front of the key to see if that works.
Unfortunately I've not been able to see if the MacBook connects to another wifi network as there aren't any unsecured ones in range. However, my iPhone connected first time to her linksys router so that seems to be working fine.
All I can think is that it must be a software quirk/bug. Does anyone have any ideas or things I can try that I've missed? Thanks in advance.
If I can't solve it we're going to have to take it back to the Apple store and play dumb I think.
edit - I've just realised that I think its a software problem yet I've posted in the hardware forum. tbh, it could be either so it can stay here.
