Macbook Pro 13" temps
12 Oct 2003
Leicester
Ok, I know a lot of people say that macbook pros get hot, but I feel like something strange is going on with mine. Right now my Macbook Pro 13" mid 2009 is idling at 68c! the room is cool, its the morning and the window is open. I feel like that temp is really high. Also i'm sure it never used to get that hot, I feel like something has changed. So I suppose my question is do you think that temp is too high, and what does your Macbook Pro idle at? Do you think apple would even consider looking at it? Thanks
That temp seems OKish. Try taxing the CPU a bit and see if the fan kicks in.
These are my temps at idle (MBP 13" 2009):
My 13" 2.2ghz uMacbook 2008 also idles at 50-51c as above. 68c tbh is high and if I had those temps then it would be the cause of an intensive task such as a flash webpage or aperture running...
