MacBook pro 2.4ghz i5
18 Oct 2002
Has any one here got the above MacBook pro and using it for aperture and iMovies possibly final cut express too? If so how does it perform?
Or is worth gettinig next one up?
If someone comes in here and says "I used both and could tell the difference", please ignore them. Spend the difference on more ram or an SSD.
I moved from a 2.4 C2D to an i7 2.66 - I use video a lot on both. Can I tell the difference? Not really, no.
Encoding is a bit quicker - you'd expect that - but otherwise it's the same experience really.
What video software u using and what hard drive speed? If I were get mbp it be the 2.4 i5
