macbook pro 2nd display?? usb??
12 Oct 2005
left abit no your other l
hi guys
i am looking for a way to plug a second vga or hdmi display in to my macbook pro is there a usb or firewire way to do this or any way that some one can come up with :D
Just by the power button is your DVI output. iirc you should have had a DVI to VGA convertor in the box ;)
If you want HDMI you'll need a DVI to HDMI Cable :)
I think he means plug in 2+ differing external displays.
This could be done on the PowerBook as there was a PC Card slot.
http://www.macworld.com/article/51797/2006/07/multimonbook.html
Matrox does this thingy
http://www.tgdaily.com/2006/03/02/matrox_3screen_tech/)
From this discussion here
http://forums.macrumors.com/archive/index.php/t-214102.html
"I now have multiple monitors working from my MacbookPro pro using the Magma ExpressBox1 Pro along with a NVidia GeForce 7300GT. It's not a cheap solution but it is the first I've seen working with each monitor treated as such by osx."
http://www.magma.com/products/pciexpress/expressbox1/index.html
Or the sidecar
http://www.digitaltigers.com/sidecar.shtml PowerBook only - maybe a Macbook Pro version to come?
