16 Mar 2009 at 10:04 #1 slickback slickback Associate Joined 12 Mar 2009 Posts 104 Which graphics card do you have your MacBook Pro set to use? Or does it depend on the workload required?
16 Mar 2009 at 10:06 #2 Stag Stag Permabanned Joined 13 Jan 2003 Posts 4,211 Location The road to erudition Thought that would be pretty obvious? If you are wanting to play a game or do intensive 3D rendering use the 9600, otherwise use the 9400.
16 Mar 2009 at 10:10 #3 slickback slickback Associate OP Joined 12 Mar 2009 Posts 104 Any issues with leaving it set to 9600 all the time?
16 Mar 2009 at 10:17 #4 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK slickback said: Any issues with leaving it set to 9600 all the time? Click to expand... Battery will run down fast.
16 Mar 2009 at 10:19 #5 Logsi Logsi Soldato Joined 19 Oct 2005 Posts 10,488 Location Kernow When I'm at home i use the 9600 but when i take it to Uni and use the battery i set it to the 9400.
16 Mar 2009 at 11:00 #6 Speedy Speedy Associate Joined 19 Dec 2007 Posts 277 Location The Netherlands I always use the 9400 when on the battery. When on power (except when only using iWork), I switch to the 9600
16 Mar 2009 at 11:52 #7 mdjmcnally mdjmcnally Associate Joined 17 May 2004 Posts 1,585 I can't remember last time I set to be 9600. So far the 9400 has done everything I need.
