macbook pro and screenshot
Permabanned
25 Oct 2006
hello can someone please tell me correctly how to do a screenshot on my macbook pro.....ive tried using the grab programme but when i click it it just sits there in the dock .....not sure how to use it or where to find the screenshot after....any help would be great
I use Command+Shift+4 and get to screen shot certain things then.
You are able to drag a box over things.
Josh
Schofield said:
hello could someone please point me in the right direction of how to make my internet safari pages full screen size :)
thanks rich
Drag the bottom right hand corner until it's as big as you like.
Why though? You will end up with lots of wasted space.
Press the + in the top left to make the window as big as it needs to be. It will automatically increase (or decrease) to fit the content of the page.
Will_3rd said:
Apple+Shift+4 = Select area for screenshot (appears on desktop)
Apple+Shift+3 = Full screenshot
Also..
Apple+shift+4 then press spacebar ;)
...allows you to do a window-specific screenshot!!
EDIT: beaten by Punky_munky :p
thanks rich
OS X isn't like Windows in the sense you can have completely full sized windows to the size of the screen - for example if I where to click the maximize on this window it only goes taller, not wider as it does not need to accomodate the rest.
You can drag the window by the tab in the bottom right hand corner if you wish (the drag tool icon is the three sequentially smaller lines at the corner) and have it what ever size you wish!
Hope this helps!
If you get stuck i'm usually on MSN and my MSN addy is in my trust if you want a quick question answering.
Rich
