Was Randomly browsing apples page under recalls to see the MacBook Pro has a battery recall.
On the page you can check your serial to see if your affected. Thankful mine is not.
Seems it affects September 2015 to February 2017.
If you have one suggest checking to see if your affected. I’ve put the link in below
https://support.apple.com/15-inch-macbook-pro-battery-recall
