Macbook = 60w
Macbook Pro = 85w
They work, but probably isn't good to use the otherway around, prob damages battery.
it shouldn't damage the battery, the design of *** charging circuitry should prevent it.
Well she was using it last night when she called me on Skype and said it was working fine with no problems, just that the brick is slightly larger than the old one.
