Earlier this year I purchased an MacBook Pro. Just the other day the HDD failed so I thought that this would be a good time to upgrade it with a bigger one.
Here lies the problem. I lost my original installation disk. So I went on Ebay and bought an OS X Leopard disk. But for some reason this disk wont install on my MBP (even though the listing said it should do, it was the disk with the lepard on the front not a grey disk). I've done a bit of googling and It seems that each disk is specific to each model or something? Is there anywhere where I can buy another Leopard disk that will install on my MBP? Or even better, some where that will sell the original disk? as at the moment my MBP has no OS installed and when I load it up I'm just greeted with an apple logo.
(my MBP is the 2011 model if that makes any difference)
Thanks
Thanks
. I'll try download Lion onto a usb first. If that fails, I'll have to cough up more money for a restore disk. Cheers
