- 3 Jun 2007
Hey folks
I recently had to take my MacBook Pro in for repair to get the right fan replaced as it was making a loud grinding sound inside the case. I got it back today and it has been working fine up until I shut it down and then turned it on again about an hour ago.
What's happening is the right fan is now constantly on, spinning at a constant 6000+ RPM, and its getting really annoying! The fan comes on as soon as the power button is pushed, and it simply won't go off. My MBP running at 41C and is cool to the touch, so I don't see why the fan needs to be on.
I've tried installing smcFanControl to manually turn the RPM's down, but I can only get the left fan to be controlled this way, the right fan won't budge from 6000+ RPM, its currently running at 6425RPM as I type this and its been the same for an hour now.
Do I take it back to the repair shop (a premium Apple reseller) and spend another fortnight without my laptop .... or is there some way I can fix it myself? Do you think wiping the hard drive and restoring with my OS X discs I got with the MacBook Pro might work?
I'm doubtful that wiping the hard drive will reconfigure the fans though, as the right fan turns on full blast as soon as the power button is pushed before it even gets to the Apple logo startup screen. I'm thinking that its probably a hardware issue now and the fan is now jammed at full RPM.
Please let me know what you think, and thanks any help,
Steve.
Steve.
