Macbook Pro Help
5 Dec 2008
Okay well i was wondering ive seen the new mac`s with a 9400M + 9600M what i dont udnerstand is according to an apple employee it mainly only uses the 9400? Why is this as the 9600 is faster?
Basicly im thinking of ordering one but i will be using it for couple games and a 9600 is what ill need it to use, is their not away to force it to use the 9600 for the games and make the 9400 be used for physx?
Help appriciated.
It's up to you which one you use, it's a user setting.
the 9400 uses less power so you get better battery life. I only used the 9600 when playing games via bootcamp but the heat is quite worrying. Although running XP is much cooler than running Win7.
