Hi all just been given a Macbook Pro 13" mid 2012.
Was told the screen was faulty, upon further inspection its looks as though it may have had water damage at some point but can't confirm.
Hard drive missing but other than that all there.
Now with the power cable connected the mac does the normal start up chime, but doesn't seem to do much else.
Now is there a way to see if the screen is faulty or if its a logic board issue?
I was thinking about getting a mini display port to hdmi to see if it did out put any picture at all but, I'm unsure how long before it would output to an external monitor. Is it as soon as it posts or once OSX has loaded.
Any help/advice links would be great.
Thanks.
Thanks.
