Hi,
Was thinking of upgrading the RAM on my Late 2011 15" Macbook Pro (i.e., the one currently being sold).
Have a couple of questions, firstly, on the Apple website it says "For best performance, fill both memory slots, installing an equal memory module in each slot." How true is this? I was thinking that 8gb is probably overkill, but if their truly is a performance hit with 6 gb, then it's not going to be worth it is it?
Secondly, what RAM am I actually looking for?
On the Apple website it says it takes...
So would the memory on this page work for example?
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=8&subid=1516
Thanks guys
- Double Data Rate Small Outline Dual Inline Memory Module (DDR3) format
- 67.6mm x 30mm (1.18 inch)
- 2 GB or 4 GB
- 204-pin
- PC3-10600 DDR3 1333 MHz type RAM
Thanks guys
