- 10 Apr 2006
- North West
Strange request, I would have put it in the wanted section but I thought it would get more of a response here as its an emergency really!
left my OSX disks at uni, will cost me £20 to get there and back.
Just backed up windows Xp, needed to resize the partition.
Merged the 2 partitions into 1, worked fine.
Went to separate the drive into 2 partitions and it says it cant, and to repair i need the OSX disks.
I think they are specific to each type of machine so i need macbook Pro OSX disks which would work on a 2.33ghz, 2gb ram, 120gb hard drive 256mb graphics.
if someone could make a copy of the disks and send me them in the post id give them a couple of quid as I need windows for a 3D Studio Max uni project!
add me to MSN if you think you can help : tom [@] tomsinclair.co.uk
Thanks!
Thanks!
