99% chance I'll be purchasing a 15" MacBook Pro at the end of the month and just wanted a few guidelines prior to purchase.
1) I didn't realise how 'poor' (?) the native resolution was, even on a 15" screen. It appears the only way to up this is to go for the glossy screen. By doing this, will this have a detrimental impact on the overall battery life between charges? If so, is this a big change?
2) This probably sounds stupid, but I'm not a hardware expert so bear with me. I've read (and had a few sources tell me) that the average battery life is about 9hrs. This is one major buying point for me, my XPS1530 has been a magnificent machine over 2 years but having a (then) battery life of 90mins and (now) a life of 40mins, it's impossible to work without it charged in. This "9hr" claim by Apple, is this based on the 'average' user or only something like webbrowsing, etc? I also see a lot of you lot mentioned about cycles or something. Because I've found out Apple use their own batteries, does this mean it's best to NOT plug into a power source if I'm near one, but ONLY if the battery is running out? I'm a little confused about this cycle talk and life of the battery.
3) For my work I still need a Windows backend (for Visual Studio, SQL Server). Based on peoples experiences which is the more reliable option to use: BootCamp or Parallels. I can see the major advantage of Parallels is that I can switch to OSX without a reboot, but if anyone does have a significant experience in running VS2010, are there any pros/cons to running it in BootCamp or Parallels?
4) Has anyone gone from an XPS1530 to a MBP 15" - any major differences you noticed? (weight, screen size, mouse pad, etc).
