You might as well go for the base model 15" over the 13" with 256gb SSD for only an extra £60 odd.
This is very true. Might change....You'd have to be mad to get the 256GB 13" over the base 15". Both are really expensive though.
Even though the 15" rMBP is smaller and lighter than the 13" MBP?You wouldn't be mad to get the 13" over the 15" if you prefer the portability...
People who used to carry around a 13" MBP and who were waiting for the 13" retina will still feel a reduction in size and weight if they got a 15" rMBP (if that makes sense). The idea of portability differences has been diminished as the 15" rMBP is so small and light anyway.You're comparing 13" MBP to 15" RMBP? Which is thinner and pretty much the same weight but not "smaller". *Confused*
Surely we're comparing retina to retina?!
If you say so. I disagree, as the size/weight difference is just 20% for both, not a big change.
