MacBook Pro Security
Yes this is possible. Insert the install disc of Mac OS X, and hold down the C key while turning on the macbook. When the installation screen appears, you can set a system password in the Utilities menu.
Would it be possible for someone to get round the system password?
Yeah, by just inserting a Mac OS X disc and resetting the password.
But there is a company that has some software to trace a stolen Macbook. I don't remember the name though...
If you insert the Mac OS X disc, you can only reset the user account password, not the EFI (Mac's version of BIOS) password. To reset the EFI password you could follow these instructions.
Encrypting the hard drive is probably the best security you can use since both user account and EFI passwords can by easily bypassed unlike hard drive encryption.
What's the best hard drive encryption app for the Mac?
You would think that with the MacBook / MacBook Pro being so expensive that apple would implement some sort of security measures to stop thieves from using your notebook if it was to get stolen.
Why hasn't anyone mentioned FileVault? It's built in and effective :)
Pretty much to secure your Mac to an insane degree:
Strong EFI Password
Strong User Account Password
FileVault turned on
Secure Virtual Memory turned on
How does drive encryption affect read/ write performance?
Since it is decrypting/encrypting files on-the-fly it will affect it somewhat. But that's why FileVault is the best option - it only encrypts your Home folder (which is the only place personal information is (should be!) stored).
For example if you were loading say Safari. The application itself will launch at full speed since it isn't encrypted but then your settings, history and bookmarks would have to be decrypted.
I would guess a large iPhoto library (since this is all stored in your Home folder) would suffer somewhat though.
It's better than full-disk encryption, worse then no encryption. Pretty much the best performance you'll get if you need to encrypt data :p
