Macbook Pro temperatures?
Man of Honour
31 Jan 2004
Plymouth
I've got a 2 year old MBP which seems to be running a bit hot - 67 idle and 80 degrees at full CPU. Both fans are reported at maximum (6000rpm) but I don't remember it being this hot before recently.
The left fan had been noisier than usual and holding the laptop to my ear I can hear a fan on the right, but not much noise on the left.
To other MBP owners...do these temps seem a bit high, and can you hear a fan on the left?
The DVD drive is also broken (ate a DVD, won't give it back and DVD drive gone from Finder now), so it's going back to Apple anyway soon :(
Knew I should've got the extended warrenty for £90 but totally forgot :(
Dust in the fans?
Probably the cause.
I have noticed my temps slowly rising, used to never pass 70C load @ 6000RPM but now 80C is possible, even if room temps are the same.
