Hi, I've been search all over the place to find the right solution to my problem with no luck at all.
Picture-wise the connection is brilliant. I'm running a DVI to HDMI cable, which works fine. The problem is that I cannot get the sound from the MacBook through the TV.
Any ideas how I go about doing this? I have bought a jack to phone cable, no luck. also bought a digital optical cable, no luck.
Any help is most appreciated.
Cheers
Cheers
