12 May 2008 at 10:35 #1 mccrum mccrum Associate Joined 25 Oct 2007 Posts 114 Location Belfast I have a MBP at the minute, but it has started to run a bit slow, does anyone know of any good utilites i could maybe run to clean it up a bit?
12 May 2008 at 11:05 #2 dannyraul dannyraul Associate Joined 15 Nov 2002 Posts 199 Location Birmingham Onyx is one of the most widely used Maintenance apps. I also use Cocktail, Yasu and TinkerTool alongside it.
12 May 2008 at 17:31 #3 J1234 J1234 Soldato Joined 16 Oct 2005 Posts 13,791 mccrum said: I have a MBP at the minute, but it has started to run a bit slow, does anyone know of any good utilites i could maybe run to clean it up a bit? Click to expand... Have a look here, http://www.the-iblog.com/2008/03/12/how-to-speed-up-your-mac/
13 May 2008 at 11:33 #4 mccrum mccrum Associate OP Joined 25 Oct 2007 Posts 114 Location Belfast Thanks guys
13 May 2008 at 15:38 #5 Deleted member 651465 Deleted member 651465 In Terminal.. Code: sudo periodic daily Enter your password and reboot. You could also try and delete the "Cache" folders from the drive.
