Started to get problems when trying to use my MacBook after it's been sleeping.
I flick up the screen and nothing happens, you can hear the sound it makes when the hard drive starts up but the screen stays off. Nothing happens if you press any keys and the only thing to do is turn it off. When you turn it on again the same thing will happen, or it will start beeping....Can be 5-10 mins before it'll eventually load up.
Also something unrelated, the macs graphic output > dvi connector never seems to work for me, I connect it, shut my MacBook so the image displays on the screen, but then the remote is unresponsive....Or it will just flicker off on the tele like i've pulled the plug out. I think since buying my MB in November last year, i've been able to use front row on my tele twice.
It's a 2.2 ghz intel core 2 duo, 4GB RAM running 10.5.3
