mach loop help
6 Mar 2008
Stoke area
Hi all,
The wife and I have both got a day off tomorrow, and although I haven't got a lens decent enough for close up shots of aircraft I thought it might be interesting to head off into Wales and see the planes.
I was wondering where the best place to go is and what sort of times we should be looking at?
Thanks :D
Take a look here.....
http://www.warplane.co.uk/Wales.htm
Generally flying is 9am onwards but you have no way on knowing if there will be any low level sorties that day.
You might not see a thing, you might get 60 passes.
If you are up for a climb go for the Bwlch, if you want an easier location to get to then go for Cad East (make sure you shut the gates behind you and park off the road).
