Specs:
Windows 2003 Enterprise
AMD Athlon 2Ghz
1Gb Corsair ram
Gigabyte 7N400 motherboard
Adaptec AAR-2410SA 64Mb
2x Maxtor 500Gb SATA drives (Stripe 0)
1x 80Gb IDE drive with O/S installed
I have been having problems trying to setup a sata array on my system. On boot I login to the bios of the adaptec card and setup my array by adding both drives. The bios says the array is created and so I reboot the system but on boot it only gets to just before the windows boot screen and haults. There is no activity from my IDE drive that has the o/s installed and the system just sits there. But if I login to the adaptec bios and delete the array the system boots fine.
I can’t understand what the problem is, can anyone help me out?
AMD Athlon 2Ghz
1Gb Corsair ram
