Hi guys, looking for a bit of assistance as I'm not a hardware bod.
Basically my rig wont switch on, I press the on button and nothing happens at all.
The psu has a rocker switch which has a light on it and this is on.
So its an old alienware case and the power button it a little circuit board, I've tested this with a volt meter and power is getting to the switch. I think the actual physical plastic button part of the button may be broken. So I have tried connecting a power switch from another pc and this does nothing either.
I've also tried touching the two power switch pins with a conductive electricians screw driver and the volt meter and these do nothing also.
It has done this before quite some time ago and to the best of my memory it just started working again after fiddling with all the cables etc but it doesn't seem to be working now.
So I am at a bit of a loss as to what to do now, I have this MOBO http://www.gigabyte.com/products/product-page.aspx?pid=3097#ov
Which I brought on OCUK a few months back as a replacement when the original one died and had an electronics friend of mine fit it for me.
So where do I go from here? I am pretty sure power is getting through, there's no obvious burnt smells but it just wont switch on
Any constructive ideas are very welcomed
Thanks in advance
Dave
Thanks in advance
Dave
