- 14 Apr 2004
- UK
I'm currently in a bit of a dilemma so I'd appreciate any advice given.
Here's the scenario: About 3-4 Months ago I bought Mini Mac from our very own MM (Cheers Neil). It was my first Mac. The Mini was used as a HTPC, It was hooked up to our Toshiba 37WLT66. It was fantastic, as I could browse the web and play all sorts of media files in our lounge. It was then that I had fallen in love with the mac, the UI is hawt
Anyhow, I sold the mini roughly 6 weeks ago hoping to buy an Intel Version (It was a top spec G4). Now the time has come to buy a new one. A few days ago whilst browsing the Mac website I saw the gorgeous Macbook. I checked out the price with HE discount and it was . . affordable (although really pushing my funds) also with me having to sell my mp3 player (Explained later). I thought to myself it would only cost an extra £360 to have a mini mac + the portability of one! It practically has similar specs of a mini and the onboard graphics seem like they would support our TV (With a few cables).
Now my parents are paying essentially £500 for it (As they initially bought the mini and have agreed to give some extra to fund towards a (notebook).
Now after doing a fair amount of research it seems I can run 3 OS's which is really the main buying aspect for me as I'll be studying Software Engineering at University.
I have however seen a fair amount of negatives, firstly the most concerning issue is that it seems the macbook has discolouration issues? I really would go for the black version but I honestly can't afford it. Could anyone elaborate more on this?
The second issue is RAM. For 3 OS's to be running smoothly 2GB seems most Ideal. Apple's prices are pretty ludicrous. I was thinking of holding off with 512mb until I find a decent set of 2GB of ram for a reasonable price. This then brings me onto my next question. Is it simple to install ram on the macbook? I had very little time to experiment with the mini, so would it be as simple as slotting in the sticks? Also I'd like to see any information regarding the technical side of RAM useage. Does it run in dual channel? Is it possible to mix and match without peformance loss etc . .
My last question probably the main deciding factor. I've heard rumours that a new macbook is due. Now having sold my mp3 player purely for the reason of knowing that I will get £100 off an Ipod. I'm stuck for choice on whether I should get it before the promotion ends or after, if it's really worth the wait? Has anyone got Idea on what will be done, will be a revamp on the model or just cpu or similar?
I'd really appreciate if anyone could offer any advice/opinions on whether it's a good/bad move. I'd also like to hear user experiences.
Thank you for your time
