Macrium Reflect questions
4 Feb 2004
Écosse
Treated myself to a new Samsung Evo 500Gb SSD to use as my O/S drive. Currently my Windows install is sitting on a 120Gb OCZ drive. I would like to clone the drive over to my new 500Gb. I used Macrium Reflect before and it worked well but what I can't remember is this.......
Does it completely clone the old drive i.e. I have MS Office and Adobe CS6 installed on that drive, will it clone those so they work right off the bat when I fire up the new drive?
Take it there won't be any issues going from an OCZ Vertex to an Evo?
Don't forget to go into disk management and extend the new drive or it'll still show as 120gb with unallocated space.
was in a similar situation, but chose to create two partitions on the ssd, keeping the OS in a smaller area (making it easier to keep an image for restore) and keep 'user' data in another paritition, contemplated putting swap space in a third partition.
Did wonder if this would all impact wear levelling on the SSD though.
What's the best/easiest way to achieve it, slave the new drive to a USB enclosure or physically fit it in the PC on a spare SATA channel?
I've used an ICy box docking station via usb3/esata on a laptop, which I also exploit for faster backups .. but if you have a sata channel/box-space ... why not.
All sorted. Macrium took 13 mins to fully clone the entire 120Gb SSD complete with all my installed software. Only problem I had during the process was that I didn't see any option to extend the new 500 Gb Samsung Evo so I didn't do it. Lo and behold upon booting back up the 500Gb Evo was sat with a 112Gb partition on it and the rest was marked as 'Unallocated Space'. Doh!!!
So I just jumped into Windows Disc Management at that point and right-clicked the OS partition in the graphic in the lower half of the main area, and selected 'Extend Partition'. Sorted. :cool:
