Macro Keys
18 Oct 2002
Overground, underground..
I have a few old Android smartphones and I found this utility
It allows the use of and Android device to send Macro keystrokes to your PC
I've downloaded the files, installed on an old smartphone (Android 4) and installed Java on my PC.
I've tried opeing the .jar containers in Java but it comes up with an error.
Error while loading log database: opening db : 'log-sqlite@: Access is denied
What am I missing?
Make sure you can write to the folder where that database lives.
Are you using maven like it says to do on their GitHub?
