I keep seeing people ask how close you have to be when working with extension tubes with macro work.
i did this quickly just to show the kinds of working distances with tubes and without, obviuolsy the distance will change depending on what magnification ration your lens is at and how many extension tubes you use. to make things simple i used all 3 tubes and set each lens at its most/least magnification.
lenses are the nikon 50mm 1.8 and the tokina 100mm 2.8 macro.
first is the tokina with no tubes at 1.1 magnification.
1
2the result
next is the tokina with 3 tubes at the least magnification.
3
4 the result
next is the tokina with 3 tubes at maximum magnification.
5
6 the result
now is the 50mm with 3 tubes at maximum magnification
7
8 the result
1
2the result
3
4 the result
5
6 the result
7
8 the result
