Made a Mistake on my build setup
23 Jan 2013
Yorkshire
Hi peeps ,
Not realized till now 3 days on and after installing all my software and Games that i have not Partitioned correctly. I have a m.2 as my boot up and root but my 2tb is now not getting used is there a way i can get this working and able to save games or other files to it without have to start from scratch?
I am on windows 10 i new noob mistake but no ones perfect
Cheers TIA
Just search from the Start Menu search box for "default save locations" you can select alternate locations / drives for saving different file types.
I assume that you have partitioned and formatted the 2Tb drive, if not, right click on Start Menu (or press Windows+X hotkey) and then select "Disk Management".
