Made it into the top 100
25 Dec 2008
Sheffield/Norwich
It took a couple of months, but I got there eventually :)
Cheers all :)
Now all I gotta do is find a couple of cheap graphics cards to start playing with the big boys :D
Hey now, cmon. Don't let Page 1 go to your head! oO
*turns up the boiler on his steam powered folding machine*
What are you folding on at the moment? Your i7 should be good for 10K PPD using a Linux SMP VM.
I'm on the ascent; running A3 SMP on Windows (A3 seems to get better results on native OS now). Folding with my i7 in sig and a 9600GT, HFM reckons I'm doing 21k PPD but it's probably nearer 20k after you take into account my usage patterns. I'm on the look out for cheapish single-slot graphics cards though, got myself four x16 slots to play with :D
Well a 9600GT is only going to be good for about 2K max, so it means the i7 is pumping out the rest of his 20K I reckon
15841.6PPD on the i7 atm (project 6012); it's normally around 16-18k though. Lowest average has been just under 15k; highest at just over 18k; and peak PPD (fastest frame) has been just under 20k. The 9600 usually gets between 2.5k - 4k PPD. :)
Damn, knew I should've hung onto my Q6600, if I hadn't sold it that'd be pushing out >10k PPD atm :( (I'd have a couple of 8600GTSs in there), looks like you're gonna start pulling away!
