Magic Sponge/Erasers
19 Oct 2002
Jupiter
...the ones that take the shine off your steering wheel etc.
Poundland have the exact same ones, same size for £1 each, rather than the £4.99 odd from JML!!
Good shout, just got one. Wonder how much it'll help on the wheel itself because I think it's more worn that dirty but there's other little grimy corners it'll be good for, worth a punt for a quid. Cheers:)
[TW]Fox;16387067 said:
Careful with these, I managed to do quite a bit of damage to a wheel with one.
How?
I've just done mine, no problem at all after a light wipe over!
Not sure I would do the dash etc though... IIRC paradigm had done most of his dash with one?
It manked mine up as well. It had grime/wear on the top half, I gave it a little go and the sponge went nice and black so I think hey ho, then it just started eating the wheel :/
Scrappy time!
You have to be quite gentle. Fortunately I had some trim peices from the E36 left over in the garage, so I tried it on that first.
If you apply too much pressure it is too abrasive for leather/vinyl.
Maybe we should sell this on eBay for £10 to the sort of people that buy those fuel magnet things?
