i think i will nab one of these to replace the stock cooler on gf sons PC
My basket at Overclockers UK:
Total: £37.73 (includes shipping: £2.74)
I'm dubious on Corsair air cooling components, have a look at Arctic, Sythe, and ofc Noctua. Arctic has better performing cpu coolers irc than the Corsair at a lower price
you can just replace the fans. corsair fans are not synonomous with QUIETNESS tbhIf I remember that review correctly, it's also a very noisy cooler. The fans have to run at high rpm to compensate.
2 lots arctic p12 is only £10. Still miles cheaper than any of the aforementioned competitors.That adds to cost. And if the cooler isn't as good at shedding its heat the fans may just have to run faster anyway.
Definitely decent that cooler. Tho people may not like the look and want a filled out case etc etc.https://www.overclockers.co.uk/arct...duo-white-cpu-cooler-2-x-120mm-hs-074-ar.html
Or just get an Arctic gpu cooler, costs couple quid less, performance up with the big boys, and 2 fans
the fan on there is ML120. Packet fans but noisy. For the a given low noise level the P12 can push more air as it is quieter. The 35db normalised test would put the stock fans at a disadvantage when compared with P12.
.https://www.overclockers.co.uk/scythe-scfm-2000-fuma-2-dual-fan-cpu-cooler-2x120-mm-hs-04f-sy.html
I nabbed one of these yesterday. Gets really good reviews and is a good price. One of my main reasons for buying it was that it doesn't have any issues with ram clearance and I've recently bought patriot viper steel ram that stands 4.4cm tall. Not sure what kind of clearance you get with the corsair cooler.
nah, exaggerated. unevenness is taken up by thermal paste anyway. if it was that crap it wouldn't have been able to cool that CPU to the same point as Noctua.I am pretty sure thats one of the selling points of the Corsair cooler.. The fans have a ratchet mechanism that allows the fans to be moved up to clearance tall ram...
One of the downsides from the GN review on that cooler was the evenness of the contact plate. Apparently across all the samples they had they were terrible inconsistent across multiple points varying from a very small amount to very big.
