Mail Chimp help needed - understanding widths
17 Jan 2006
Hi All
My workplace is looking at using Mail Chimp for various mailouts and at present we are putting together a design for this, however I've hit a stumbling block...
Using one of the built-in templates, with a body section and a sidebar, but I'm having trouble with the the header block of the design as it seems to be a different width to the rest of the email and as such, it doesn't properly line up with the edges of the body and side bar, which looks a bit rubbish...
I've sort of worked around it by using a table width command to specifiy the width of a picture and caption frame but it's still not great as there is padding on the frame and hence unwanted space around the header picture but I can't seem to do anything about that.
Does any have any experience with such issues on Mail Chimp and any ideas how to get around it?
Any help would be very much appreciated.
Thanks
Without a screenshot or HTML it's a bit difficult to picture the problem. Is it because your header block image isn't very wide?
Also, if you're not wanting space around the header block image, you can tick "Edge to edge" margins in the image settings, which will remove all whitespace around the image.
