Mail + Fonts
  • Thread starter Thread starter wij
  • Start date Start date
wij
wij
27 Dec 2006
Recently noticed that message I send to people who are PC users using Outlook 2007 seem to be getting my messages displayed in Times New Roman instead of Arial or whatever the nicer font is :)
My signature though appears in the correct formatting, what I cant figure out though is if this is a problem with the way Mail is sending the messages or in the way Outlook is putting them back together.
Google seems to show others having this issue, but I can't seem to find a fix for it :(
Are you sending the messages in a RTF format, or is Outlook setup to use a Times New Roman default font for messages?
I'd bet it's the latter.
Looks lime I'm sending in RTF, fairly sure its always been that way though...
No it wont be the latter as if I send an email to the same person from Outlook/Thunderbird on my PC is appears in the correct formatting.
And any replies I get from people show their text in something like Ariel and my text as Times New Roman.
Not really a bit issue, its just annoying me :)
Just make sure the message compose and default inbox fonts are set to what you like in Mail?
