- 23 Sep 2012
- South Yorkshire, UK
Hi folks, need some advice...
Ok, so, the other day I installed my new XFX 7950 Black Edition into my Akasa ZEN black Midi-ATX case....and the two PCIE power cable plugs are too close to where the side panel would be, so, on the advise of a friend of ours who does IT for a living, i've pretty much been told to look for a bigger case
, it was generally agreed upon that i'd need one at least 12 inches wide.
I've taken a liking to the Cosmos 2, since i'm looking for a case that has good cable management, excellent airflow (my current case has neither when both side panels are on), room for expansion/easy hard-drive installation, and most importantly, hinged side panels.
Now onto the nitty-gritty...
My current system is an Asus LGA775 P5K mainboard (ATX), Q6600 cpu, Tuniq 120mm LED cooler, 8GB TwinMX DDR2 (4 DIMMs), DVD/CD+RW and a SATA 2 3Gb/s 400GB HDD, and of course, my XFX 7950.
Now, according to my motherboard manual, the board only has 3 fan connectors, and one of them is for the cpu cooler, the other two are case fans, so i know i'll have to pick and choose which ones i want to use, unless i can used use one of those Q-Connector things, but i doubt it.
So, my first question is this:
Is my main board really compatible with something like the Cosmos 2? And if not, does anyone have any suggestions?
Also, when my mother and I installed the new GPU, we had to push the back of the case inwards to make the screw holes in the case line up with the screw holes on the card's backplate, something my mother wasn't comfortable doing. Would i have that same issue with the Cosmos 2?
And lastly, I'm also thinking of upgrading my power supply, I'm currently using a Corsair VX550w, and yesterday, i had a couple of issues with this thing locking up on me, after a bit of messing around (and reading the "Overclocking failed!" message at boot-up), i've determined that my psu might be struggling with the more hungry card (I messed around with the OC settings, and setting it to 30% stopped Windows from starting up, so i had to set all my OC settings to AUTO), either that, or the PCI-E x16 1.1 (so GPU-Z reads it as) slot is bottle-necking the 3.0 card, though my gut tells me its a psu issue.
What would you guys recommend? 750W? 850W? Fully modular or semi-modular?
Thanks in advance.
Thanks in advance.
