Hi I am seeking some advice on a general workstation build, max budget of £450ish. required specs as follows to include the following, but not limited to;
Mobo - (DDR3 - HDMI - USB 3)
CPU - Quadcore
RAM - 8gb DDR3
Case - open to suggestions
HDD - 2tb (separate or singular, which ever is cheaper/better option)
Card reader - bay or built in to case
Drive - DVD player (no need for blu-ray)
Fans - quiet, also to fit chosen case
PSU - dependant on build, once again open to suggestion
WIFi - open to suggestion, probably a dual signal card
GPU - possibly not required if mobo is adequate, machine used only for general emails, music, films, but will be used to play rome total war from time to time, as I understand it, it is old but quite system heavy game?
Any advice offered is much appreciated, many thanks.
CPU - Quadcore
RAM - 8gb DDR3
