OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder today we have the new Kolink Balance Midi Tower Case - The Balance is aptly named, as it has a good balance of aesthetics, features and performance. The Balance supports a plethora of hardware, including E-ATX motherboards, dual radiators (360mm at the front, 280mm at the top), 370mm VGA cards both horizontally and even vertically (dual slot only, PCI-E riser cable sold separately), 162mm CPU coolers and ATX PSU's. There's an angled ARGB strip on the front of the case, and an ARGB rear 12cm fan, both of which can be controlled either by the RGB button on the I/O, or via a compatible ARGB motherboard connector. Up to 4 x 2.5" drives can be installed, plus a pair of 3.5" drives.
The front panel has both mesh and solid characteristics to allow airflow whilst maintain nice aesthetics. All in all, for £49.99, the Balance offers a hell of a lot of value for money. Stock will be available in the next two weeks so preorder today!
Kolink Balance ARGB Midi Tower Case - Black Window @ £49.99 inc VAT
Stylish Midi-Tower from Kolink, Integrated aRGB-LED strip, Fits E-ATX motherboards, Pre-installed 120mm aRGB fan, 2x 3.5"-/4x 2.5" slots, RGB I/O & motherboard control, supports 360mm/280mm radiators
Only £49.99 inc VAT.
ORDER NOW
ORDER NOW
