Can anyone tell me what is the best way of flushing Mayhems pastel fluid out of my loop?
Its due its first fluid change plus I am adding more components to the loop over christmas. I also thought it would be the perfect opportunity to change fluid colour whilst I am breaking into the loop.
I am renewing the tubing but I am re-using the res, pump and CPU block...will the dye have permanently stained my clear plexi res and CPU block?
Advice would be much appreciated
Cheers.
Cheers.
