Major data loss **** up
26 Mar 2004
Long story short i mixed up 2 hard drives.
Bunged a Mac HDD from a macbook onto a PC using a usb caddy and formatted as NTFS.
Some important info on that hard drive and i NEED it back.
Any help or tips i would be every so grateful.
recuva stayed on 0% for an hour.
I've used it many times before and its never done that. so i quit.
Any way long story short again, i'm a bit panicky and not thinking straight and I reformatted it in journal and i'm trying to recover it using a mac now.
Pretty much trying all the free trials.
Don't think formatting again was the best idea. Expect data recovery apps to take a long time as it continually scans the same point of the hard drive over and over. I'm not sure on Recuva's algorithm if it gives up after a specified amount of tries but it was your best bet.
but does recuva work on Mac OS Extended drives?
it was originally not an NTFS, so could getbackdata or recuva work?
