Major Hardware upgrade without re-installing W10?
15 Oct 2014
Somerset England
As per the title, is there any chance of me swapping out my current Haswell rig with a new Skylake-X one without having to re-install Windows 10?
Before you say it, yes I know a fresh install is preferable with most, but it takes me forever and a day to install and configure all my specialist Art software packages with all the various brushes etc that the thought of doing it again makes me want to throw up lol!
I would be more inclined to put my upgrade of till next year if I cant do this - so what are you thoughts? :)
I have swapped out a AMD mobo\ram\cpu for a intel mobo\cpu\ram before and used the same install of windows but as you said I clean install would be the better option as you may run in to issues.
Might be worth going into device manager and uninstalling all the chipset drivers etc for your current mobo and then do the swap, that would stop a bit of confusion in windows when you put the new mobo in, not tried it myself but just a thought.
Sounds like a good idea actually!
I also read somewhere that Windows 10 is generally more forgiving with major hardware swaps compared to the days of Windows 7 or even 8...
Windows 8 is as forgiving about major hardware changes as 10 is as it just picks up that new hardware and installs the new drivers.
You also don't have to remove the old chipset drivers as they will be dropped when the new setup is configured.
The only issue you'll have is if the license is from an upgrade or an OEM, you'll have to go through some hoops to get it reactivated if that is possible since moving upgrade/OEM activations is normally only for when major hardware components fail.
Now that is of concern, as I had a free upgrade - maybe if I contact MS and ask them about it ahead of my upgrade..
Rr
502 bad gateway.
Has anybody managed it though? I did a google on the topic and found quite a few people who claimed to have done it with minimal fuss.. One noted that it took around 15 minutes to boot the first time, whilst chipset drivers installed, and it's run perfect ever since as if nothing had changed.
I have used it on client machines and it's saved me hours of work.
Was the original license an OEM or a retail key as it should take the status of the original key (unless microsoft are being a pain in the you know what and are considering upgrades locked to the hardware they were used on).
Regardless, you might be able to get it reactivated within windows 10 since it allows for that and I doubt that they'll ask about why the changes had to happen (which is why I said normally).
I honestly cant remember if it was OEM or retail...
I just found this, looks like they have a tool for this now!
http://www.windowscentral.com/how-re-activate-windows-10-after-hardware-change
If you do have any issues and have to reinstall, I recommend doing the new install alongside the old one and copy stuff from the old to the new like program configs and stuff then deleting the old one.
I went from Sandybridge on an old P67 board to Haswell-E on X99 without a problem. Re-activated using the built in tool after upgrade.
Just turned off, swapped all the hardware and switched on. No messing around with drivers.
your hardware change would be a new PC to Microsoft and as its never been activated the chances are slim it will activate permanently on an OEM license from teh old machine, worst case scenario is it works for a trial period and you have to buy another key, not so bad really
As long as you link your Microsoft account to your windows account, you should be able to re-activate it no issue.
Also I have been surprised at how tolerant Windows 10 is with being moved to different hardware configurations, after the first boot and the new hardware has been detected, it works fine.
I'm not so sure, as long as my Microsoft account is linked to my windows 10 license which it is, the built-in reactivity on tool should work fine surley?
Does it really matter if it was originally a win 8 oem key or retail?
Here hopeing! :)
Good to hear! Was your original key oem or retail do you know?
